Author Topic: Black vinyl strip around rear window  (Read 1362 times)
Offline Lee Watson
« on: 11 April 2005, 14:19 »
Hi
I've just purchased a second hand tailgate for my MK2 GTI 16v as mine is almost dead, I've striped it down
so I can remove any rust before spraying but I'm not sure of the best way to remove the black vinyl strip
around the window.
Has anyone got any idea's?  :shocked: :shocked: :undecided:
Lee
Offline Gambit
Re: Black vinyl strip around rear window
« Reply #1 on: 11 April 2005, 14:41 »
heat it and pull it off then use tar remover or something similar to remove any left over residue
i assume you have the glass n all removed?
u can get a new surround from www.gpcvwaudi.com for £25
Offline Lee Watson
« Reply #2 on: 11 April 2005, 14:46 »
Cheers mate I'll give that a go at the weekend.
Thanks for the web address as well.
Offline The Hoax
« Reply #3 on: 11 April 2005, 20:39 »
It's a complete pisser when you hit the strip at an angle with your jet wash and rip chunks out of it. I have done this to two cars - Doh!
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 12 April 2005, 07:44 »
mine was removed years ago so I don't have to worry.
Bluemk2 has his sprayed on...
Judderi
« Reply #5 on: 13 April 2005, 14:52 »
Use a paint stripper heat gun. Apply a little heat then grab a corner and start peeling slowly. Its real easy once you get going.
