Author Topic: Mixture screw tuning???  (Read 1496 times)
Offline Jonoyorko
« on: 13 July 2011, 09:14 »
Hi, thought I read a thread on here somewhere that you can
Change the mixture screw setting to get better performance!
Is this true? I have got mk2 golf gti 8v digi, I have also drilled
The airbox does mixture need to be adjusted for this?
Any help much appreciated as new to this!!
Re: Mixture screw tuning???
« Reply #1 on: 13 July 2011, 09:18 »
Better to leave alone tbh.  :smiley:
Also it is controlled by the ecu on a digi.
« Last Edit: 13 July 2011, 09:20 by Wayne »
Offline Jonoyorko
« Reply #2 on: 13 July 2011, 09:22 »
Ok cheers, is that bad? I'm after any advice on wot to mod on it.
Offline SoundillusioN
« Reply #3 on: 14 July 2011, 17:00 »
Because you have digi, your airflow sensor detects how much air is being drawn in and will increase the fuel to match, to a certain extent anyway.  If you drilling your air box has increased airflow, the ecu will match the fuel.
