Author Topic: ecu removal  (Read 3129 times)
Offline candywhitefudd
ecu removal
« on: 12 July 2011, 20:52 »
any 1 know how to remove ecu ????????
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: ecu removal
« Reply #1 on: 12 July 2011, 21:16 »
Scuttle panel off, bulk head cover in the engine bay comes off with 10mm nuts, then it's a matter of bending the security mount around the ecu so you have room to unclip the ecu plugs a then slide the ecu out.  Another way is to drill or grind off the shear bolts.
 01455 617233
Offline The Doc
  • E63s Estate - Vito Sport
Re: ecu removal
« Reply #2 on: 12 July 2011, 21:34 »
I'd not bend the ECU cage nor take a drill or grinder to it....
Instead take your time and use a dremel to score small slots into the security bolts on the ECU cage and use a flat head screwdriver to unscrew them, then if you want to replace the security bolts you can buy new ones from VW and jobs a good 'un  :wink:
I'll post some pics to show you what I mean on Friday when I'm back in the UK.
Offline RTechUK
Re: ecu removal
« Reply #3 on: 13 July 2011, 07:50 »
I will try that next time :-)
 The method to bend the mount works well but involves a lot of manipulation, it's only the back of the security tab that gets bent just enough to slide the ecu back to get the front plug off, then the whole cage and ecu will come out with ease, and can go back in tidy. Only down fall with this method is cut and scratched nuckles :-(
 01455 617233
Re: ecu removal
« Reply #4 on: 13 July 2011, 12:47 »
thanks for ya help fellas  :smiley: just gotta find a new ecu,,,,,,any1 no where to look pls
Offline RTechUK
Re: ecu removal
« Reply #5 on: 13 July 2011, 12:53 »
Whats up with your current ecu?  and what part numbers?
Nick
 01455 617233
