Author Topic: Wheel spacers? Good or bad?  (Read 2712 times)
Offline craig4004
  • I love MK4's, All about the ££££ Though :/
« on: 12 July 2011, 15:41 »
Got me some wheels for my mk4, all refurbed etc, went to fit them and the inside rubbed on the strut on the fronts :( I'm thinking 5mm spacers will sort it but not sure Wich ones to get. I'm seriously low on budget and saw there are universal shims that are £10 per pair that will fit. I then saw the hub-centric ones which were a lot more expensive. I wondered if anyone could enlighten me on what the difference is, and weather the universal shims would be ok for now? Cheers :)
Offline andc1
Re: Wheel spacers? Good or bad?
« Reply #1 on: 12 July 2011, 17:06 »
you dont need hubcentric for 5mm, try and find some that are the correct bore size to reduce wheel wobble
Offline daz veedub
  • Operation 1.8t bolf
« Reply #2 on: 12 July 2011, 17:21 »
hubcentric are for the correct bore size i.e 57.1 for the mk4
shims are not and can cause wheel wobble
i paid £40 for 5mm spacers with correct bore size off ebay mate
Offline GTI:Gibbo
« Reply #3 on: 12 July 2011, 18:08 »
What size have you got on the rear Daz?
Offline daz veedub
« Reply #4 on: 12 July 2011, 18:10 »
did have 20mm on rear but removed due to over scrubbage  :lipsrsealed:
Offline GTI:Gibbo
« Reply #5 on: 12 July 2011, 18:13 »
I thought that might be a problem with 20mm.. I think i will go for 15mm Hubcentric for the rear of mine.
Offline daz veedub
« Reply #6 on: 12 July 2011, 18:20 »
think iam gona go 10mm rear as i have took adjusters off rear coilovers.. should sit just right then  :smiley:
Offline GTI:Gibbo
« Reply #7 on: 12 July 2011, 18:25 »
What coilovers are you on?  :undecided:
Offline daz veedub
« Reply #8 on: 12 July 2011, 18:28 »
jamex 1s mate been on 12mths now  :smiley:
Offline GTI:Gibbo
« Reply #9 on: 12 July 2011, 18:34 »
What is the height adjustment on them mate?
