Author Topic: Interior Sensor Fault  (Read 2674 times)
Offline benmanc
« on: 12 July 2011, 12:00 »
My alarm keeps going off and its starting to do my head in.  It could be a problem with my door lock module as that needs replacing but im also getting code 01135.
I found a page on mkIV's which says...
Quote
When the alarm has gone off you can find out what set it off by using VAG-COM.  Go into the CCM (address 46) and look at measuring group 16.
Now, I dont understand what this measuring group 16 means?  What do I go on once im on the CCM module on the programme?
Offline Ant1981
  • Feed me, prod me
Re: Interior Sensor Fault
« Reply #1 on: 12 July 2011, 12:10 »
01135 - Interior Monitoring Sensors: Open Circuit
Possible Causes
    Wiring/Connector from/to Interior Monitoring Sensors faulty
    Interior Monitoring Sensors not installed
Possible Solutions
    Check/Repair Wiring/Connector from/to Interior Monitoring Sensors
        See Measuring Blocks
    Check Interior Monitoring Sensors Installation
'09 Kawasaki Ninja ZX-6R
Offline benmanc
« Reply #2 on: 12 July 2011, 21:42 »
Will have a look although not a clue what to look for on the connections or where the other end goes
Offline rhys1927
« Reply #3 on: 16 July 2011, 08:59 »
Also check that your rear washer jet isn't leaking.
The leak can cause the alarm to continuously go off!
Offline benmanc
« Reply #4 on: 16 July 2011, 09:18 »
Its a fault with the interior sensor not the boot sensor.
