Author Topic: rattle from head on run down - question  (Read 2985 times)
Offline Cory
« on: 11 July 2011, 17:34 »
the car has developed a rattly head on comedown over the last couple of days. had a little listen through a screw driver (if that makes sence) and the rattle is quite distinct. also i removed the oil cap and there is a little white ish smoke coming out.
possible head gasket failure, with broken bits rattling loose inside?
im only just learning about engines so if its a stupid question/reasoning then go easy on me!
Offline Thom89
  • Looking for an "Icebreaker"
Re: rattle from head on run down - question
« Reply #1 on: 11 July 2011, 19:35 »
What engine? and have you checked your oil level is correct, and a small amount of smoke is normal when removing the filler cap...
Thom
« Reply #2 on: 11 July 2011, 21:32 »
Could be many things.
Broken valve spring maybe :smiley:
Offline Sam
  • Sam I am
« Reply #3 on: 11 July 2011, 22:13 »
Asking about 'an engine rattle' on here is the equivalent of typing into yahoo answers 'headache', you will think you have a brain tumour and require surgery in no time  :grin:
Offline danny_p
« Reply #4 on: 11 July 2011, 22:47 »
very true.    you'll get people like me posting pictures like this.
that was a "tappet rattel" that developed   :evil:
all the VW's have gone bar 1.
Offline raferackstraw
« Reply #5 on: 11 July 2011, 22:54 »
only in your case caister the 'rattle' is usually a brain tumour  :grin: :grin: :grin:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline mwep201081
« Reply #6 on: 11 July 2011, 23:38 »
Could be a loose heat shield
Check the simple stuff first before you go replacing valve springs...
« Reply #7 on: 11 July 2011, 23:51 »
lol  :laugh: :laugh: :laugh:
Offline Sam
  • Sam I am
« Reply #8 on: 13 July 2011, 17:25 »
And thats why I love her  :grin:
Offline Cory
« Reply #9 on: 13 July 2011, 18:46 »
thanks guys. tho i have found the culprit, and now feel like an utter plonker.
bottom alternator bolt was missing, hense the rattling noise . . .
