Author Topic: AGU performance issues.  (Read 2870 times)
Offline xxChrisxx
« on: 11 July 2011, 13:31 »
I'm having some issues. Car's just rolled over 121K, everything is standard and pretty well maintained. No smoke, doesn't use any oil, compression on all cylinders is good.
Symptoms:
Painfully slow.
Throttle response is awful.
Whistling whilst spooling up and 'on boost'.
Turbo surge (fluttering) even though the DV is fine.
Smells slightly rich, but not enough to give a failed lambda reading. (spark plugs have very slight carbon fouling).
It hard to describe but the throttle has no 'resistance'. It used to have a steady acceleration as you progressively opened the throttle. Now nothing at all until the throttle is fully open (and then still nothing). I have noticed there there seems to be a small amount of oil in the breather pipe. My gut says a hole in a pipe somewhere, but short of taking off every single pipe I can't find one. Are there any common pipes that split?
Any ideas would be appreciated.
Offline daz veedub
  • Operation 1.8t bolf
Re: AGU performance issues.
« Reply #1 on: 11 July 2011, 13:37 »
check all boost pipes
clean throttle bodie
have u scanned for any fault codes
Offline rio_gti
« Reply #2 on: 11 July 2011, 13:45 »
clean throttle body out for starters,
check all oost pipes but also pipes to n75 valve, also wires to n75 valve as it might not be working properly
what dv is it??
try and get someone with vagcom to scan it, and log to see you may have a failing maf,
Offline xxChrisxx
« Reply #3 on: 11 July 2011, 13:53 »
I had the throttle body off for a clean not long ago.
Though I've had a cursory look at the boost pipes, i'll have to take them off and inspect one by one. Unless anyone has a lazyman's method?
I suspect this is acutally the problem, but taking off each one is a total faff.
Everything on the car is OEM, or decent alternative. The Bosch valve works fine.
It's been tried with a known good MAF and is exactly the same.
I'll try to get it scanned sometime soon.
« Last Edit: 11 July 2011, 13:55 by xxChrisxx »
Offline daz veedub
« Reply #4 on: 11 July 2011, 13:55 »
if all pipes are standerd am guessing 1 has perished or spilt  :wink:
Offline sprout99
« Reply #5 on: 11 July 2011, 14:21 »
MAF??
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline rio_gti
« Reply #6 on: 11 July 2011, 14:56 »
when you say there is no go in it, do you mean that it will only do a max of somethin like 30 mph?? if so the cat may have collapsed  :undecided:
how do you know the dv works fine??
Offline xxChrisxx
« Reply #7 on: 11 July 2011, 15:24 »
Nah it's nothing catastrophic. It'll still go and sit happily at motorway speeds, it just doesn't accelerate on sliproads.
DV works fine becuase it's been tested with one that is known to be good.
Offline gavgtiturbo
« Reply #8 on: 11 July 2011, 16:00 »
my moneys on intrcooler pipes,boost pipes or breather pipes
Offline Ant1981
  • Feed me, prod me
« Reply #9 on: 11 July 2011, 16:05 »
I wonder if there's a diagram of the boost pipe system?
'09 Kawasaki Ninja ZX-6R
