Author Topic: Infinity fitting problems?  (Read 3508 times)
Offline takethefifth
« on: 10 April 2005, 23:11 »
Just wondering if anyone could reccomend some easy fit good quality 3.5" speakers?  Do the JBL's drop straight in?
I got some infinitys and the drivers side drops in sweetly but for some reason the passenger side doesn't want to sit down properly - i reckon its the connection point against the foam stuff thats in there. Anyone else had this problem or have a handy solution?
And while i am on the subject - infinity 6x4's - why couldn't i get them to fit? Is it just me or were the holes just a bit too far apart... and yes i removed the larger fitter plate first. Would be interested to know if anyone else has had this problem?   Replaced them with JBL's today and they fitted perfectly, no hassle.
Offline Mr Blue
Re: Infinity fitting problems?
« Reply #1 on: 10 April 2005, 23:26 »
just jam the fronts in there! :tongue:
I took my parcel shelf support off and measured how far they were out and drilled holes so that it fits flush. (drilled on the frame of the speaker that is :rolleyes: )
My infinity rears are only held on by two bolts coz i snapped the other two off as they got in the way
hows that? :wink:
Offline Paulie1.8
  • Please be patient...still learning
« Reply #2 on: 11 April 2005, 01:46 »
Got Infinity rears too.
Don't fit properly...and sound crap because they rattle against the shelf supports.
They've been in about two weeks, and I'm now awaiting my Alpine 6x9s and acoustic shelf to arrive! :embarassed:
IMO really not worth swapping the 6x4s. Found that out the hard way.  :cry:
Offline SarahD
« Reply #3 on: 11 April 2005, 15:49 »
my infinity components dont sit in my door pods properly cos the cone is too deep  :sad: gunna have to cut holes in the door cards so they fit  :cry:
« Reply #4 on: 12 April 2005, 00:09 »
Thanks everyone, it wasn't just me!  :grin:
Dumped the rears cos they rattle too much due to not sitting properly, didn't want to 'make' them fit as i don't like destroying anything on my golf no matter how small! Cheers anyway.
Fronts are in but passenger one is wonky and you can hear the difference as it bounces off the windscreen at a different angle, need some different ones!
Any suggestions? - and again, i would rather not destroy anything to get them in properly!
I do like my music! I am hoping door pod conversion things and component speakers (not infinity, thanks sassy) with a 12" sub in the rear should give a reasonable amount of midbass in the front which is sorely lacking at the mo.
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 12 April 2005, 07:43 »
I found running 13cm in the front lacks a little mid range even when I was running a 10" sub. now I'm running 17cm and it seems to be a little better, but I haven't finished building my pods yet so hopefully they'll get better still. I made the pods so I didn't have to cut the cards
« Reply #6 on: 14 April 2005, 17:41 »
Cheers Dizzie. Guess i will just have to make do until i can get round to doing it properly. Component 17cm in the doors sounds like my best bet.. Don't suppose you make door pods as well as lighting looms?  :wink:
PS. My old golf is going for spares or repair if anyone is interested - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9873&item=4543351523&rd=1
Offline hockeylad72
« Reply #7 on: 15 April 2005, 17:41 »
have just put in 13cm 2way alpine speakers in my door pockets. you can get new grilles for door pockets form vw dealership at around £20 inc vat. I would say that is probably the best way to go. I have also put in 12" sub with 4 channel amp which also powers front speakers very impressed with results
hope this helps
Davie
Offline wellfan
« Reply #8 on: 15 April 2005, 18:59 »
hockeylad72, are you saying vw dealers are selling the grilles that replace the door pocket for about £20, folks pay silly money for these on ebay. Is the price for two grilles including all fittings and do you have the part number.
Offline wellfan
« Reply #9 on: 15 April 2005, 19:05 »
I have a spare set of Pioneer TS-876 front dash speakers, bought them on ebay (as a complete set of front and rears), only needed the rears as I already have a front set. What are they worth to someone?
