Golf mk3
hardmonkeys
what causes?????????
Topic: what causes????????? (Read 879 times)
drewz2511
Just got here
09 July 2011, 14:39 »
what courses clutch judder??? i have a mk3 golf gti 2.0 8v on a k reg and the clutch judders when pulling off and how many stud should they be 4 or 5? and do they as standard have discs on the back? any help please cheers adam
dragongreengolfgti
my golf gti mk3
Re: what causes?????????
09 July 2011, 14:44 »
could be clutch cable is to old there self adjusting on them but i think you can buy a manual adjusting one from the dealers. Also could be the actual clutch is giving up is it slipping at all? and yes there 5 stud on gti models on mk3 and have disks on the back the pcd is 5x100 256 mm i think someone will correct me on that im sure
drewz2511
Just got here
09 July 2011, 15:21 »
nice one cheers for your help yeah it does slip a bit the previous owner put new clutch cable on so it might be the clutch thanks for help
Wayne
Sir Postalot
09 July 2011, 23:06 »
Check for any play in the engine mounts.
gti gaz
09 July 2011, 23:50 »
i had new cable and still did it then changed engine mounts problem solved seams strange but solved problem frunt one is easy as pie back 2 are not to bad but quite tight to get to good luck
Any one in cornwall lets sort more meets!!!!
Golf mk3
hardmonkeys
