Author Topic: Door lock module repair - wish me luck boys!  (Read 8875 times)
Offline richw911
Re: wish me luck boys!
« Reply #20 on: 09 July 2011, 21:01 »
I've got an idea.
I'll have a go at saving the moola, by getting a micro switch from RS and I'll make it fit. It'll work alright, but I'll either alraldite it in place or use some M2 bolts. Sod paying £120 for a module, which is what VW quoted me last week. Only reason I never got one, is I have to order it as they don't keep it, but I never managed to order it as they won't place orders over the phone.
Once that's done, I'll have a write up for you chaps that the mods can sticky if they like it.
Sounds like a good idea to me  :smiley:
Offline Ant1981
  • Feed me, prod me
« Reply #21 on: 10 July 2011, 10:21 »
Something like that.......
here's the buggered one....
« Last Edit: 10 July 2011, 11:40 by Ant1981 »
'09 Kawasaki Ninja ZX-6R
Offline Rhyso
« Reply #22 on: 10 July 2011, 11:15 »
First impression is that looked a bit like a Claymore mine  :laugh: :laugh:
Good effort; lets hope it works!  :smiley:
Offline mattkh
« Reply #23 on: 10 July 2011, 17:16 »
........ so cutting it out will stop....the fuel pump from priming 100 times a day.
Hi
Is that really true ?
Offline Ant1981
  • Feed me, prod me
« Reply #24 on: 10 July 2011, 17:24 »
Hi
Yes, as with the switch cut out, then there is no sticky switch.
The door is registered as open if the switch contacts are closed. My switch was mostly stuck closed, telling the car that the door is open, with intermittent opening of the contacts.
So cutting the switch out leaves the door 'closed', until I source a switch.
I think I may need to revisit the door module, as I'm uncertain about wheather or not it's put back together properly, as now the alarm doesn't set and if I press lock, then lock again, the drivers door unlocks. So I may have jiggled the mechanics of the module about to make or not make another microswitch activate or deactivate properly.
It's alot of messing about, I must admit, in an attempt to save £120, but it's given me a real insight into how this all works.
Offline Ant1981
  • Feed me, prod me
Re: Door lock module repair - wish me luck boys!
« Reply #25 on: 11 July 2011, 10:53 »
Here's my old Burgess microswitch....
the top and the bottom can be seperated
Here's a new Burgess microswitch
http://uk.rs-online.com/web/p/micro-switches/1571020/
which I'm going to seperate to use the new top with the old bottom, as the bottom part of the switch works perfectly, it's only the old top plunger that has worn.
Now, before I go any further, I really need to see if I can find out what exactly the other four microswitches inside the module do, as it's only since taking it apart that my alarm doesn't set and the door unlocks if I press lock a second time.
« Last Edit: 11 July 2011, 11:01 by Ant1981 »
Offline mattkh
« Reply #26 on: 11 July 2011, 13:07 »
..... it's only the old top plunger that has worn.
Hi
I am most grateful to you for the photos.
Can you not 'build up' the plunger with some resin/epoxy ?
Offline shedpainter
« Reply #27 on: 11 July 2011, 20:09 »
I've been following this thread because I think I've got a bit of bother with the module on mine. Had a search and found this link that might be useful................
http://www.scribd.com/doc/56214783/2/Control-units
How you gettin' on? Any more pics?
Offline Ant1981
  • Feed me, prod me
« Reply #28 on: 11 July 2011, 20:18 »
Excellent find.
I've ordered my switch, hopefully at the weekend I'll do some more. I'll take the module apart again and see if I can jiggle things around and get it to work how it did before.
