Author Topic: how close does your tyre sit near your coilovers????  (Read 1827 times)
Offline darren1.8t
  • I HATE FRENCH CARS
hi guys i have a funny noise coming from my pass side wheel??? just looked at it and the tyre has gone bald on the inside? the noise is very weird sounds like a rubbing/knocking noise? im running 225/40/18 its only started to do it for about 3 month lol i looked and the wheel/tyre are only just away from the round adjuster on the coilover ??? it seems a bit close to me? the drivers side is fine!! any idea? could the coilover be shagged??? cheers
Offline Dave_IOW
Re: how close does your tyre sit near your coilovers????
« Reply #1 on: 09 July 2011, 10:45 »
maybe you need 5mm spacers, maybe you need your tracking sorted.
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline darren1.8t
« Reply #2 on: 09 July 2011, 11:17 »
it has 9mm spacers m8 the drivers side is ok but pass aint?? i think the shock has gone?? :angry: :angry:
Offline Dave_IOW
« Reply #3 on: 09 July 2011, 11:30 »
cant have buckled that far   :shocked:
Offline vwfiend
« Reply #4 on: 09 July 2011, 11:32 »
Mine had less than a rizla packet width with no spacers which was fine until my tyre went flat and the adjustment ring ripped the sidewall apart. As long as you have a gap, it should never change. What tyres/wheels you running?
Offline houston
« Reply #5 on: 09 July 2011, 15:49 »
Did you replace the top mounts? Is the coilover body still in the hub properly? And is it all the way in?
Offline darren1.8t
« Reply #6 on: 09 July 2011, 18:35 »
im running 225/40/18 and i just replaced the top mounts i just did drive shaft so i will see?? its had all new wishbones track rod ends etc etc i just dont no???  :sad:
« Reply #7 on: 09 July 2011, 23:08 »
If really close run a thin spacer also check and see if you have any play in the wheel bearing.
Offline darren1.8t
« Reply #8 on: 10 July 2011, 08:22 »
cheers wayne im running 10mil spacers on both sides !its weird as the drivers side has more of a gap than the passenger side? im gonna do a rear wheel bearing today and have another look!! im still thinking that the coilover is shot?
Offline AaronGS
« Reply #9 on: 10 July 2011, 11:10 »
could your wheel be buckled at all? Also, its not just the tyre size that matters but the particular wheels offset and the coilover setup that determines that gap. raising it a smidge may solve your issue. May also be worth getting someone decent to do a wheel alignment on it?
