Author Topic: after Relay numbers  (Read 2008 times)
Offline Gareth
after Relay numbers
« on: 09 July 2011, 02:43 »
i have a ce1 fuse box and i'm missing a few relays. i have found lots of info what number relay does what but i have not found any thing on what number relay should be in the corresponding number on the fuse board. here is what i have found so far:
1 Open or Digifant relay
2 Fuel pump (fuel injected) OR Glow plugs (diesel) OR inlet manifold heater (Carb)
3 Seat belt warning
4 Upshift indicator (1985-1987)
5 A/C relay
6 Dual horns
7 Open
8 Load reduction
9 Open
10 Intermittent wipers
11 Rear wiper
12 Turn signals, flashers
13 Open or power windows
14 Cooling fan after-run (except 16-valve)
15 Passive restraint (1988, 1989) or ABS/coolant temperature relay
16 Idle air stabilizer
17 A/C thermofuse or ABS
18 Coolant level indicator
19 Power windows
20 Heated seats (left)
21 Heated seats (right)
22 Oxygen sensor system power supply (US cars w/CIS) / Automatic transmission relay
23 Power window fuse (30A)
24 Glow plug fuse (Diesel-50A)
can any one help me out? thanks
Offline dragonfly
Re: after Relay numbers
« Reply #1 on: 09 July 2011, 18:32 »
« Last Edit: 09 July 2011, 18:35 by dragonfly »
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 09 July 2011, 21:30 »
For More Info Click To See;
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 09 July 2011, 21:37 »
1 Open or Digifant relay No 30
2 Fuel pump (fuel injected) OR Glow plugs (diesel) OR inlet manifold heater (Carb) No 167
3 Seat belt warning ?
4 Upshift indicator (1985-1987) ?
5 A/C relay No147
6 Dual horns
7 Open
8 Load reduction No 100
9 Open
10 Intermittent wipers No19, 229 or upgrade with 99
11 Rear wiper No 72
12 Turn signals, flashers No 21
13 Open or power windows 3 Think
19 Power windows
I Think...
