Author Topic: Full beams causing engine to high rev :S  (Read 1570 times)
Offline Gareth
« on: 09 July 2011, 01:48 »
morning all,
got a very strange problem every time i put the full beams on it causes the idle control valve to full open and stays open until you turn them off :/ its not opening because the engine is about to stall it's strange.
any one else come across this problem?
Offline Thom89
  • Looking for an "Icebreaker"
Re: Full beams causing engine to high rev :S
« Reply #1 on: 09 July 2011, 02:12 »
Not one ive heard of before. but sounds like it may be an earthing issue, check all body to engine earthing points, that they are clean and tight
Thom
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #2 on: 11 July 2011, 14:05 »
This sounds like an alternator problem to me or even a battery problem as the full beams use a sh!t load of amps in comparasion to standard dipped. Check the voltage of the battery with the engine off then see what it is when the engine is running, then flip the full beams on and check the voltage again. If the voltage drops loads then your alternator could be shot.
Worth a check but I could be completely wrong
Offline russ-vdub
« Reply #3 on: 11 July 2011, 14:06 »
Actually ignore what i said, this only applies if the revs drop. DOH!
Offline Gareth
« Reply #4 on: 12 July 2011, 00:10 »
thanks for your help guys :) i have found the problem it was a damaged headlight switch sending live down the neutral
