Author Topic: Heater Problem?  (Read 1521 times)
Offline Whysub
Heater Problem?
« on: 10 April 2005, 19:39 »
Odd, but the heater on my newly acquired 1.6 8v works fine, but as soon as the temperature gauge gets to halfway, it only blows cold air. When the gauge drops a little, it blows hot again.
Checked the cooling system for leaks (none) and the oil/water for signs of water/oil, but all fine. A 200 mile round trip on motorway and stop start traffic showed no cooling faults.
Summer is coming, so it will not be a problem, but would like to know why it does this. Is it simply the thermostat?
Offline robiwill
Re: Heater Problem?
« Reply #1 on: 10 April 2005, 21:17 »
its the heater bypass valve that is blocked take it off and clean it, if that doesnt cure it then you need a replacement
Offline Whysub
Re: Heater Problem?
« Reply #2 on: 14 April 2005, 17:37 »
Thanks-at least I have a place to start the investigation.
Offline Organisys
  • Old and Slow...
Re: Heater Problem?
« Reply #3 on: 14 April 2005, 21:44 »
Check for airlocks.
Set heater to max hot with fan on also.
Run car from cold with coolant expansion tank cap off.
Massage all coolant hoses (including heater send) hose
Air bubbles will rise up through tank.
Wait for coolant to nearly boil.
Stop engine
Wait for coolant to cool right down,
Top up coolant if needed. Replace cap.
Worked on mine.
diagnosis-dub
Re: Heater Problem?
« Reply #4 on: 15 April 2005, 14:17 »
Spot on. you know it makes sense :wink:
