Author Topic: Stripping Front Seats  (Read 1975 times)
Offline 8vSukhi
« on: 08 July 2011, 13:55 »
Hi,
I've got some spare front seats that I need to take apart so that I can use them to repair the saggy bolsters on the seats fitted to my car.
I've removed the plastic side covers, removed the circlips, removed the seat adjustment knob and from there can't work out how to split the base from the backrest. Do I need to remove the large screw where they hinge (had a quick go very tight and very easy to damage screw head so didn't progress with that one)
I did read somewhere that once the circlips are off then it's just a case of jiggling the base/backrest about until the come apart. Tried that but had no joy.
Any help would be appreciated.
Thanks
Sukhi
Offline molegti
Re: Stripping Front Seats
« Reply #1 on: 08 July 2011, 14:02 »
The large screw needs to come out i used a impact driver.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 08 July 2011, 21:40 »
3 door or 5 door seats?
For More Info Click To See;
Offline 8vSukhi
« Reply #3 on: 10 July 2011, 11:31 »
Hi,
I've got 3 & 5 door seats that need stripping.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 10 July 2011, 21:21 »
3 door seats lean them forward and take the clipoff and the seats will come apart...
5 door you have to remove the one fixed seat guide and screw - I use a 3/8th ratchet drive with a screw head attachment with a large bit to get leverage to free up the screw and then fold them forward like a 3 door seat.
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #5 on: 15 July 2011, 23:03 »
Are you putting the 3 door seats back together or splitting them? I need the tilt levers and bits that make it tilt if you have them handy?
