Author Topic: air bag removal  (Read 1810 times)
Offline sharki786
  • GOT BOOST??
air bag removal
« on: 08 July 2011, 11:27 »
as above realy, will be taking dash out and wanted to know which is the best way to take the air bags out?
disconnect battery 1st obvioulsy.
but how will the pas side airbag come out?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Luke1981
Re: air bag removal
« Reply #1 on: 08 July 2011, 13:02 »
Don't quote me on this but I think the best way is to remove the glove box compartment which will give you the space to get behind the dash. You will then be able to see the airbag module and connectors. Separate the airbag connectors and the module should be attached to the dash by 4 bolts. Once these are removed then the module should pull out.
As you stated before make sure the battery is disconnected and make sure when handling the module the exterior trim plate is always facing away from you.
I would wait for a second opinion of somebody else first mate before attempting to remove it.
Good luck  :smiley:
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline sharki786
  • GOT BOOST??
Re: air bag removal
« Reply #2 on: 08 July 2011, 13:05 »
cheers mate. i will do! :smiley:
*****MK4 GTI T*****
Offline Len
Re: air bag removal
« Reply #3 on: 08 July 2011, 13:14 »
Not got a passenger side one so cant help there.
Have done the steering wheel a couple of times and thats easy. Just disconnect battery, both terminals, and wait 15 minutes.
www.sas.org.uk
www.the-ace.org.uk
Offline sharki786
  • GOT BOOST??
Re: air bag removal
« Reply #4 on: 08 July 2011, 15:08 »
going to be taking out the dash so will be taking BOTH air bags out. gonna be a b1tch to do.
*****MK4 GTI T*****
Re: air bag removal
« Reply #5 on: 08 July 2011, 15:36 »
Why are you taking them out  :undecided:
Offline sharki786
  • GOT BOOST??
Re: air bag removal
« Reply #6 on: 08 July 2011, 15:39 »
going to put in the climatronic :wink:
*****MK4 GTI T*****
Re: air bag removal
« Reply #7 on: 08 July 2011, 15:44 »
Madness  :smiley: good luck I think you would be better sticking to the standard set up.
Changing the heater itself is a ballache of the job.
Offline Len
Re: air bag removal
« Reply #8 on: 08 July 2011, 16:00 »
Definitely good luck with that!
Got climatronic in the Passat and I prefer the simple system in the Golf!
www.sas.org.uk
www.the-ace.org.uk
Offline chiefwhosm
Re: air bag removal
« Reply #9 on: 08 July 2011, 19:34 »
Quote
Feel free to make a how to guide for anyone else mad enough to do it (I'm told by one person that it takes several weeks mind, so would be a big tutorial)   :smiley:
