Author Topic: Power steering noise....  (Read 12881 times)
joe88_gti
« on: 08 July 2011, 09:03 »
hi my golf gti 1.8T makes a terrible whining noise when turning the steering wheel left or right
i'm thinking it could be the power steering?
can i just top the power steering fluid up? or do i need to replace the pump?
will a new pump be expensive?#
cheers
Offline master_oogwai
Re: Power steering noise....
« Reply #1 on: 08 July 2011, 09:39 »
I had this problem last year and also this year. Both times resulted me paying out for a new steering rack, as the rack was leaking fluid.
Like you, the steering rack started to whine when turning the wheel either to the left or right.
First port of call would be to check your PAS fluid.
VW charged me around £1100 all in last year and this price included wheel alignment (£99)
This year, I went somewhere else, but still cost me over £600 incl new front tie rod ends and wheel alignment.
joe88_gti
« Reply #2 on: 08 July 2011, 10:21 »
wow that is alot of money. i might check the fluid level first
Offline houston
« Reply #3 on: 08 July 2011, 14:38 »
obviously check the fluid first! could be something as simple as a small leak, in which case you can get an oil seal additive rather than pay out for a new rack
joe88_gti
« Reply #4 on: 08 July 2011, 15:00 »
i'll see if it needs topping up but to be honest i've never noticed any wet patches under my car
could the pump itself be screwed?
Offline rio_gti
« Reply #5 on: 08 July 2011, 16:59 »
sounds like a mini cooper then??  :grin:
yeah check fluid also check in the bay mine was leakin just above the pump (well still is its only minimal!!)
front left hand side
Offline Steve_PD
« Reply #6 on: 08 July 2011, 17:57 »
top the fuild up and keep and eye on the level. New rack may be needed soon..... :lipsrsealed:
« Reply #7 on: 08 July 2011, 21:23 »
Check level and bleed the system as a 1st step.
Offline houston
« Reply #8 on: 09 July 2011, 11:43 »
exactly where mine was leaking, have you tightened the nut? i managed to get half a turn on mine and its been no bother since
