Golf mk3
hardmonkeys
Rear Caliper Guide/Slide Pins Question
Topic: Rear Caliper Guide/Slide Pins Question (Read 1746 times)
leegt5
07 July 2011, 23:58 »
On my rear passenger side i have the below 2 slide pins
The squared off one has no play in it left to right when fitted but the other does. Is this supposed to be loose like this as I've tried 2 identical second hand pins of the top type and they do it as well......
So my question is should the pins be tight in the pad carrier but move in and out and should the squared one be in the bottom or top ?
Support London's Air Ambulance
harlemex
Re: Rear Caliper Guide/Slide Pins Question
08 July 2011, 11:12 »
they should have little play. Try swappin them around. I think the bores in which they sit in wear, which is gay, as VW only sell the carriers and pins together.
AudiA8Quattro
Forum addict
08 July 2011, 21:30 »
I do have a pair of mk3 rear carriers, brand new, i am open to offers
leegt5
08 July 2011, 23:17 »
Quote from: AudiA8Quattro on 08 July 2011, 21:30
You couldn't tell us which end of the carrier has the squared guide pin in could you ?
Golf mk3
hardmonkeys
