Author Topic: mk1 golf jetta front  (Read 5111 times)
Offline travisreeve
« on: 07 July 2011, 23:06 »
does anyone know much about the mk1 golf jetta front coversion asin whats needed obv lights and grill but what about front panel ect ect
Offline Jack3559
Re: mk1 golf jetta front
« Reply #1 on: 08 July 2011, 08:48 »
I think I remember Shaun saying in his build thread that is was slightly more involved than other mks in that it required wings and slam panel.
Offline SoundillusioN
« Reply #2 on: 08 July 2011, 09:49 »
Correct. :afro:
To accommodate the lights you'll need the front end off a donor car, bare in mind this is not a simple bolt on job as MK1's are fully welded!
You'll need:
Jetta front panel, Ideally part of the inner wings as they are slightly different due to indicator placement, New outer wings or at least the front corners for the same reason, and a bumper with no indicators holes.
Then you have the fun of grinding off your front panel and some inner wing area to weld on the new stuff.  Last time I saw a ready to use panel it was going for £200.
« Reply #3 on: 08 July 2011, 09:53 »
Oh and I know you have the skills to do it but haven't you finished your front end once already!  :shocked:  :grin:
Offline DubFan
« Reply #4 on: 08 July 2011, 23:57 »
Is the USA Rabbit front an easier swap with smaller square headlights that fit in the grill?
« Reply #5 on: 09 July 2011, 12:13 »
There were a couple of variations.  This one is the same score as the above pretty much.
Where as this one which I prefer only needs the front panel
Bare in mind though that both will require the grilles, lights etc. I'm sure it won't be easy finding the bits required if you fancied it. US eBay/forums??
