Author Topic: Weekend of de rusting  (Read 2177 times)
Offline dubvrs
« on: 10 April 2005, 18:37 »
Well my car is going in to be sprayed on the 16th April and wanted to get the car ready but got carried away a bit  :grin:
Took off the front panel and found some rust and thought i can do a bit of spraying.
Even did the spare wheel well as there was a slight rust patch around the drain hole
Offline Snap
  • Just smile, stop being miserable!! :-)
Re: Weekend of de rusting
« Reply #1 on: 10 April 2005, 21:24 »
Looks good. How do you de-rust? Whats the process before painting when you find rust?
'92 1.8 Mk2 Golf, carbed GU... [SOLD]
Offline dubvrs
« Reply #2 on: 11 April 2005, 12:59 »
I just use a wire wheel on my drill to remove the loose rust then a flap wheel to sand it down. Put on some rust eater that chemicaly neutralises the rust and spray over it with anti rust primer.
Sugar79
« Reply #3 on: 21 April 2005, 15:11 »
done a good job there mate!!  :smiley:
