Author Topic: Lower front strut brace help please !!!  (Read 3525 times)
Offline townerboy
« on: 07 July 2011, 18:54 »
just bought a lower front strut brace and it wont go on it's too short now maybe its the wrong length or worst way is car is slightly bent it is an 83 cab so wouldn't be suprised, is the distance between the lower arm front bolts the same on all mk1's and does anyone know what it should be ,its not much out but enough that i cant fir the bar !!!please help!!! aarrgghh :cry:
Mk4 1.8t
Re: Lower front strut brace help please !!!
« Reply #1 on: 07 July 2011, 21:24 »
Is it a solid or adjustable type.
Offline SoundillusioN
« Reply #2 on: 07 July 2011, 21:31 »
Should be the same on all mk1s.  How far out is it and are you 100% sure its for a mk1?
Offline townerboy
« Reply #3 on: 11 July 2011, 18:33 »
i bought it and it was listed as for mk1 gti from demon tweeks so i can only assume it's correct and it's the solid one it's a straight bar type the ones that had bends in them where listed as for the mk1.3 i believe, i would also assume that all the main chassis legs and the base of the mk1 woudl be the same apart from differences in cabriolet and 5door models or are they different ?
Mk4 1.8t
« Reply #4 on: 11 July 2011, 21:01 »
Right here goes, over time the chassis legs on mk1's spread apart, adjustable is easier as you fit it then pull the legs in, not so easy to fit a solid one.
Offline townerboy
« Reply #5 on: 11 July 2011, 22:22 »
so maybe lots of blood sweat and tears and maybe some heat to go with it then or give in and get an udjustable one  :angry:
Mk4 1.8t
Offline raferackstraw
« Reply #6 on: 11 July 2011, 22:32 »
yep get an adjustable one unless you have equipment to pull legs back into line
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
« Reply #7 on: 11 July 2011, 23:34 »
I have seen it done with a ratchet strap  :grin:
