Author Topic: 1.8T Clutch Slip, surely it should have given up by now!!  (Read 2089 times)
Offline wilson
I first noticed my clutch starting to slip now and then around sept last year,  car is 100% standard and used daily, including a 400 mile round trip once a month.
It doesnt always slip, only now and then,  but surely by now it should have given up completely or at least got considerably worse.
Since it started slipping I priced up having a new one, or getting rid of the dual mass as advised elsewhere on this site.  but because it hasn't got any worse I havent bothered!!
A long shot, but is it possible it could it be something else causing the slip,  seeing as it hasnt worn out yet??
Thanks
Wilson
Offline gtti_234
Re: 1.8T Clutch Slip, surely it should have given up by now!!
« Reply #1 on: 07 July 2011, 15:12 »
If it is the clutch you dont want that to go bang you will b using tweesers to get all the little fragments out of the gear box. A liquid based substance may have leaked onto you flywheel courseing it to slip either way you had better check it.
spax coil overs, 18ins rs8 alloys,007 forge dv,n75j,piper cross induction, r-tech stage 2 remap, custom chromes decat exhaust + 3" down pipe, forge actuator g60 flywheel vr6 clutch, forge tip, deleted pvc catch can install,
Offline wilson
« Reply #2 on: 07 July 2011, 15:28 »
dont you think thats a long time for it just to be slipping now and then?
From previous cars ive owned in the past with normal clutches I've had two need replacing, and they only lasted a couple of months, before it slips so much it virtually undrivable.
Offline Toby
  • Car - less
« Reply #3 on: 07 July 2011, 18:09 »
mine went from slipping to cracked in a week! but i just had the car remaped, and i was caning the hell outa it that week!
but it dont sound goood, get it cheked anyway! :undecided:
Currently down under
Offline houston
« Reply #4 on: 08 July 2011, 14:42 »
do you boot it often? clutch can last for ages with slipping if you dont drive aggressive.
has the clutch/brake fluid been changed recently?
Offline wilson
« Reply #5 on: 08 July 2011, 14:45 »
No dont really tend to put my foot down much unless i'm out on an open road,  I'm a bit of a safety first driver :S
Yes, had new discs pads and brake fluid, 8-10 weeks ago.   Does the Brake and Clutch use same fluid then???
Offline houston
« Reply #6 on: 08 July 2011, 19:32 »
Yes it does. Did you bleed the lines when you done the brakes? Could be summit as simple as a weak clutch cylinder action or line needing bled
« Reply #7 on: 08 July 2011, 21:19 »
You could have a small oil leak that is getting onto the clutch.
Offline golf-sib
  • Турботазик
« Reply #8 on: 10 July 2011, 00:28 »
Mine was slipping for ages, it started only slipping only in 5th on a very rare occasion and that was with a remap. Several months later it became more frequent especially with a loaded car and camping. Then two months later it was getting worse and worse by day. They do put up a good fight on the way out compared to my polo's clutch which gave up so quickly.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline Ant1981
  • Feed me, prod me
« Reply #9 on: 10 July 2011, 10:23 »
If it's slipping, you'll be scoring your flywheel anyway, so may aswell get the flywheel and clutch conversion done.
'09 Kawasaki Ninja ZX-6R
