Author Topic: Gti Anniversary Help with Tyre Pressures & Alarm  (Read 1563 times)
Offline patc
« on: 07 July 2011, 12:41 »
Hi,
Just a couple of questions from a new owner.
Tyre pressures - I have the BBS alloys on the Anniversary Edition with 215/40 16 tyres.  Petrol cap says pressures 36/33.  Is this true?  Just seems a bit high.
Alarm - I have a red light on a square with Clifford on under the radio and I can see an alarm under the bonnet.  I have no alarm fob.  Was this standard on the model?  I assume it is disconnected as there are no lights/beeps.  Just wondered if I could get a replacement fob?
Cheers in advance.
PatC
PatC
Golf GTI MK3 Anniversary Edition
Re: Gti Anniversary Help with Tyre Pressures & Alarm
« Reply #1 on: 07 July 2011, 13:00 »
Tyre pressures are correct, however 32 all round will be fine.
Offline Len
« Reply #2 on: 07 July 2011, 13:24 »
I find that the lower the tyre profile the less air pressure you need.
I run mine (205/40 x 17) on 30 front 28 rear.
Clifford not standard!
They are generally considered to be the best aftermarket alarms though.
Have to find a local Clifford dealer mate.
www.sas.org.uk
www.the-ace.org.uk
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #3 on: 07 July 2011, 13:27 »
Red Clifford light and square base means its a G4
if the light flashes slow, its not turned on, u might just need new fobs and have them coded in
best alarms
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Gash
« Reply #4 on: 07 July 2011, 15:23 »
60 psi for me! haha
Offline patc
« Reply #5 on: 07 July 2011, 22:13 »
Thanks.
Light on the Clifford alarm is not on at all.  I'll find a local Clifford dealer to see if they can shed any light.
PatC
PatC
