Author Topic: Part Throttle Hesitation - Golf mk2 16v  (Read 1496 times)
Offline mk2rolf16v
« on: 07 July 2011, 03:29 »
hi,
ive a 1990 gti 16valve.... i notice while driving on motorways, part throttle about 2.5k rpm theres slight hesitation, and its not til i apply full throttle that is goes away. any ideas what it could be?
ive previously read on a mk3 thread that they talk about a faulty ecu relay, dont think i have such relay on mine  :undecided:....
pls help!!
Offline sprout99
Re: Part Throttle Hesitation - Golf mk2 16v
« Reply #1 on: 07 July 2011, 07:25 »
metering head?
injector ?
fuel pump?
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline dragonfly
« Reply #2 on: 07 July 2011, 08:22 »
Check the wiring on the throttle switch - when was the accelerator pedal cable replaced?
Offline mk2rolf16v
« Reply #3 on: 07 July 2011, 22:52 »
accelerator cable has never been replaced since i owned the car which is about 4 years now, but since owning it - about 2 years ago i replaced both fuel pumps, fuel pump housing with new hoses, fuel filter, fuel accumulator... even though there didnt seem anything wrong with metering head i replaced with a working second hand one, had co-emissions setup done recently at mot station and all seems to be running fine. although the parts being over 2 years old now should there still be concern for parts failure??
few weeks ago i had ignition timing done and car now gives 32.5mpg, is that ok?
as for the  accelerator cable what effect would it have with regards to symptoms?
« Last Edit: 07 July 2011, 22:53 by mk2rolf16v »
