Author Topic: Top mount adjustment.....?  (Read 1630 times)
Offline javalin
« on: 06 July 2011, 21:32 »
Hello,
I've noticed that my GTI is lower on the o/s/f than the n/s/f, its about 10-20mm.
Can this be adjusted with the top mount position - i.e. shorten/lengthen the spring?   Also how do you know how to adjust/setup the position of the top of the spring?
ta
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Screech16v
  • MK3 20vt AGU
Re: Top mount adjustment.....?
« Reply #1 on: 06 July 2011, 22:37 »
Do you have adjustable coilovers,if not you may have a broken coil spring .
Offline javalin
« Reply #2 on: 06 July 2011, 22:50 »
no - std springs as far as I am aware.  Spring looks normal to me at least.
Offline trog_nfs
« Reply #3 on: 06 July 2011, 22:52 »
Any leakage from the shocks?
Also have you had either side of the car jacked up, as can take a while to settle again
« Reply #4 on: 06 July 2011, 23:34 »
Sounds more like a broken spring. :smiley:
Offline AudiA8Quattro
« Reply #5 on: 06 July 2011, 23:58 »
Are the springs seated properly?
It is possible one of the mounts is more worn, can you post a pic?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #6 on: 07 July 2011, 00:18 »
Are you fat?
Offline javalin
« Reply #7 on: 07 July 2011, 08:38 »
>Are you fat?
No - 10-20mm is without a driver or passenger inside the car.
yes.
couldn't see anything on the o/s/f
Have had the o/s/f strut out to look and all seems fine.
How do you know where to tighten the top mount bolts up to?  I.e. I have a bit of scope to compress the springs with them by the looks of things.
James
« Reply #8 on: 07 July 2011, 10:56 »
Offline SoundillusioN
« Reply #9 on: 07 July 2011, 11:42 »
Sounds like a busted spring and to look at it probably will look fine, usually the first coil or two breaks and then the car sits on the 3rd and hides the coils that have sheared off.  I missed it on the others halfs car not so long ago.
