Author Topic: Steering column assembly  (Read 1247 times)
Offline jackytwoshoes
« on: 06 July 2011, 18:54 »
I'm a bit confused here...
I think I've re-assembled my steering column correctly but when I insert the spring behind the spline adapter I can't get the steering wheel on far enough to reach the horn contact.
Have I assembled the steering column in this order:
Steering column outer tube
Steering lock
Rubber bush between bearing and inner
Indicator/wiper stalks
Spring
Spline adapter
steering wheel
washer
nut.
Correct?
Offline Simeon
Re: Steering column assembly
« Reply #1 on: 07 July 2011, 00:35 »
Tighten the nut more
Offline The Mighty Elvi
  • I'm better than you today.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 07 July 2011, 21:50 »
sounds like the spline adaptor hasn't gone on far enough... Did you take it off in the 1st place?
For More Info Click To See;
Offline Gareth
« Reply #4 on: 12 July 2011, 00:18 »
on the steering column case there is a bit of metal that stick out, make sure it has fully inserted into the lock case
