Author Topic: mk4 key fob issue -------- locked out ! UPDATE  (Read 10440 times)
Offline Ant1981
  • Feed me, prod me
Re: mk4 key fob issue -------- locked out!
« Reply #10 on: 06 July 2011, 12:43 »
thanks very much for the reply, so if i smash a window and gain access, would you say my key would start the car?
I reckon you'd start it, as the electronics for the locking unlocking isn't anything to do with the starting. But your car will be deadlocked, so you'll have to climb through a broken window.
One reason I'd never go for 'delocked' doors, as if you could get the key in, you'd be in.
'09 Kawasaki Ninja ZX-6R
Offline cullygti
« Reply #11 on: 06 July 2011, 12:43 »
mine does this now and again i just put key in the door turn left turn right and then my fob works its worth a try  :wink:
Offline andyj775
« Reply #12 on: 06 July 2011, 12:45 »
regrettably its delocked so unable to do the above. im a lot more optimistic now anyway, thanks guys
Offline Rhyso
« Reply #13 on: 06 July 2011, 12:47 »
Knackered door module in the drivers door by the sounds of it
You need to get it scanned as it will tell you exactly what's up with it  :smiley:
Will a scan show up a door module? Thought the scan only covered things with parametric sensors.
My door module is shot also, but it'll let me unlock on the button, it's the locking that it won't do as it thinks the door is open, on my car anyway.
It does indeed  :smiley:  Using VAGCOM, go into Module 46; central convenience.  Scanned a MK4 last night that showed faults with 3 out of 4 doors  :shocked: :shocked: :sad:
Offline cullygti
« Reply #14 on: 06 July 2011, 12:48 »
didnt you find 2 on mine rhyso  :grin:
Offline Ant1981
  • Feed me, prod me
« Reply #15 on: 06 July 2011, 12:52 »
Does the free version of vagcom scan everything? All I need is a usb lead for that, right? I've got a scanner, but only does the engine things I think.
Offline StusDUB
« Reply #16 on: 06 July 2011, 12:53 »
nope free one scans everything even radio  :cool:
Offline Ant1981
  • Feed me, prod me
« Reply #17 on: 06 July 2011, 12:58 »
Aplogies for hijacking someones thread, although information may benefit him also, if I got one of these http://cgi.ebay.co.uk/VAG-USB-DIAGNOSTIC-CABLE-409-1-OBD2-II-LEAD-VAG-COM-/330399696070?pt=UK_Diagnostic_Tools_Equipment&hash=item4ced5b44c6 what could I do/scan? Would that program my spare key that I got from VW?
Offline andyj775
« Reply #18 on: 06 July 2011, 13:01 »
no worries mate all infos good info here and know a lot more now than at the start  :wink:
Offline Rhyso
« Reply #19 on: 06 July 2011, 13:32 »
You need the full version to program keys  :nerd:
