Author Topic: Best way to remove badges  (Read 3032 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 04 July 2011, 10:10 »
Would like to remove my GTI and GOLF badges on the motor...any good tekkers I should be aware of?
Offline SoundillusioN
Re: Best way to remove badges
« Reply #1 on: 04 July 2011, 10:21 »
Hot water and old credit card, or hair dryer and thin wire.  if the car is a few years old you may need cutting paste for the exposed paints fade.
http://www.torquecars.com/styling/de-badging-cars.php
« Reply #2 on: 04 July 2011, 11:36 »
I did mine yesterday, all I did was to work fishing line behind the badge to cut the adhesive then clean off with meths afterwards.
chrisuk
« Reply #3 on: 16 July 2011, 15:48 »
I used the hot water/credit card/patience combo on my old golf.
Dont try to clear off any left over adhesive with a green side of a dish sponge though!  :drool:
Offline _Adam_
« Reply #4 on: 21 July 2011, 17:21 »
+1 card and meths :smiley:
Offline GTI:Gibbo
« Reply #5 on: 07 August 2011, 21:21 »
I used hot water from the kettle and then worked dental floss around back of badges and they came off nicely... There was some glue left on the paintwork so i used white spirits and gently rubbed with a small sponge and the job was done.  :smiley:
Offline golf nutter
« Reply #6 on: 12 August 2011, 18:00 »
hot dairdryer and dental floss!  :grin:  and then get blisters on your fingers as you rub the residue off...all good fun, but worth it...will be doing mine tomorrow if the weather is any good.
Mk7 GTi; Mk5 GTi; Mk4 GT TDI; Mk3 VR6; Mk1 GTi;
Mk1 GTi Sportline
Offline ja55on
« Reply #7 on: 12 August 2011, 18:35 »
nearly but easier way
plastic card scraper, bank card (or Ni Card) will do fine *** dont use Drivers licence you may break it and nobody likes shelling out 20 notes for a new one
and then to get the sticky off use a rubber toffee wheel (found in all good halfrauds) put that on the drill werrrrrrr it away... **dont be too rough it can take paint off but if your sensible its fine
the toffee wheel was standard issue when i worked at romford and essex accident repair as a technician
