Golf mk3
hardmonkeys
Timing That Skips? = SOLVED
Topic: Timing That Skips? = SOLVED (Read 1706 times)
Twubble
DJ Twubble
Re: Why does the timing skip?
Reply #10 on:
15 July 2011, 08:22 »
Thanks for that!
here's the culprit: cam shaft pulley
Here, you can see that the crank shaft pulley's lock key magically disappeared (right)
I changed the crank shaft pulley, the cam shaft pulley, and the timing belt's tensioner.
Wow....
nikkiy9
GTI forum regular
Reply #11 on:
15 July 2011, 09:47 »
i've had the woodruf key snap on me before but it was on a fiat punto, at least you know what the problem was and have got it sorted now
Golf mk3
hardmonkeys
