Author Topic: Scanning car noob  (Read 3775 times)
Offline benmanc
Scanning car noob
« on: 03 July 2011, 20:29 »
I scanned my car the other day as I had a boost leak which I have now sorted.  I have an ebay usb cable with the free version of vag com.
It had this below when I scanned it.  I think its not showing what the faults are as its the free version?  Is that correct?  and does anybody know what the faults are from what it shows below?
 VCDS-Lite Version: Release 1.1
Saturday, 02 July 2011, 08:58:09.
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: Redir Fail!
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00028
   VCID: 69A53EA70077
No fault code found.
Readiness: N/A
Address 03: ABS Brakes       Labels: 1J0-907-37x-ABS.LBL
   Controller: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 00028
   VCID: 3FF1C0FF2E73
jamie16v
Re: Scanning car noob
« Reply #1 on: 03 July 2011, 20:51 »
from what i can see, there are no faults, appart from what i imagine would be a link error  :undecided:
Offline Big Tone
« Reply #2 on: 04 July 2011, 06:17 »
It says no fault code found.
It does however only show the first two modules, I presume that you are using the autoscan faculty and its booting you out after scanning address 3. Yes?
Have you tried scanning the modules individually?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
