Author Topic: Trying to fit Momo steering wheel  (Read 1501 times)
Offline kagero465
« on: 02 July 2011, 19:29 »
Hey there,
I have a Momo corse steering wheel and a Mountney boss/hub/whatever. In the instructions with the hub it says to remove the splined bush before fitting the hub.
Problem is the splined bush doesn't want to come off!
Anyone done this operation before? I don't want to put heat on it. Or knock about too much.
If it's too big a deal, I'll just try and get my mone back and buy a Momo one.
Hope someone can help. How do I get pictures up?!
Cheers for reading.
Nick
Offline i_am_me
Re: Trying to fit Momo steering wheel
« Reply #1 on: 02 July 2011, 23:36 »
when i did mine i struggled with it.
i ended up clamping a pair of mole grips on the collar then putting a bearing puller onto the steering columb and over the mole grips then pulled it off.
<br />
If at first you don't succeed skydiving is not for you
Offline DOA
« Reply #2 on: 02 July 2011, 23:47 »
Easiest way is to hit the end of the column with a hammer (seriously!) and the collar pings off. IIRC there is a bolt that lightly clamps the collapsable part of the column that needs undoing first but its been a while since I did it to mine.
Offline cняis
« Reply #3 on: 03 July 2011, 00:06 »
I personally dont like the idea of belting the steering column with a hammer, but it is telescopic (in case of an accident) so will take quite a beating. I tried the hammer and 3 legged puller methods on my old project and it still wouldnt come off  :angry:
Offline DOA
« Reply #4 on: 03 July 2011, 17:35 »
Me either!! However, I couldnt get a puller on there so the whacking stick got used instead lol.
Offline kagero465
« Reply #5 on: 06 July 2011, 23:46 »
Hey,
Thanks for all the advice.
I took it back and got them to order me one with the bigger spline!!
Momo steering wheel looking great on now  :smiley:
Cars nearly finished. Gona put pics up in the project section in a couple of weeks.
Cheers again.
Nick
