Author Topic: Advice needed?!?!? 2.0 16v ACE v's KR  (Read 1602 times)
Offline neilgriff78
« on: 30 June 2011, 21:32 »
Can anyone please tell me if i can fit a KR head to a 2.0 ACE block just wondering because the shape of the pistons are different betwwen the ACE block and the KR block, dont want to bolt together and have bounceing valves lol.
many thanks in advance!
Re: Advice needed?!?!? 2.0 16v ACE v's KR
« Reply #1 on: 30 June 2011, 23:52 »
Nope I think you need to change pistons plus other mods.  :undecided:
Offline neilgriff78
« Reply #2 on: 01 July 2011, 20:25 »
would it be as simple as swoping the pistons over or would it be better to just put the KR cams into the ACE head?
Offline danny_p
« Reply #3 on: 02 July 2011, 11:13 »
ACE dosent go as well on kr cams.
and before you swap the heads have a look at the kr's exaust port you'll soon change your mind
the 027 big port head has a crap exhaust port  your better off with the 051 head unless your going to port the problem out ace has 051 head  but cut out for higher lift cams
all the VW's have gone bar 1.
Offline neilgriff78
« Reply #4 on: 02 July 2011, 13:04 »
Confussed now what to do for max bhp output, i have both complete engines (KR/ACE both working perfect before removal) so able to swop and change parts at will.
Offline danny_p
« Reply #5 on: 03 July 2011, 18:17 »
i would use the ace cyl head, port it and reprofile the cams
you may see i bit more max bhp useing the std kr head on the ace bottom end over the std ace head but the sacrifice in torque isn't worth it imo
