Author Topic: Oil Pressure Sender MK2 golf g60  (Read 1386 times)
Offline delirical
  • Like a g60
« on: 30 June 2011, 14:53 »
I have all my VDO guages fitted and working but..
I think i may have the wrong VDO sender, this is the one i purchased:
http://cgi.ebay.co.uk/VDO-OIL-PRESSURE-SENDER-/220806153092?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3369128384
When you accelerate the guage climbes to about 3 bar but when you cruising along it drops to about 0.5 bar and the oil light flashes on but goes off again when you accelerate or when engine braking (under load)
The light never came on before the two pole sender was fitted, so do i have the wrong 'bar' sender as the one i have is 10bar...?
Please help as the oil light flashing is very annoying!
Offline Mr Blue
Re: Oil Pressure Sender MK2 golf g60
« Reply #1 on: 30 June 2011, 17:06 »
did you fit the sender to the head or oil filter housing?
When cold it should be near max then drop down once warm.
Offline delirical
  • Like a g60
« Reply #2 on: 05 July 2011, 08:31 »
Fitted it to the head, checked again and when cold it is 3-4bar but when warm it drops to 0.5 and the oil light on the dash starts flashing.
Offline Steve_B
« Reply #3 on: 05 July 2011, 10:18 »
Iirc you should put a 5 bar sensor on the head. Could always try putting it on oil filter housing instead.
