Author Topic: Mk 4 engine transplant  (Read 1599 times)
Offline rowley177
« on: 30 June 2011, 13:18 »
Does anyone knowe if it is (or has been done) possible to fit a Cupra R engine into a MK 4 golf GTi (non turbo)?
 :undecided:
(Please no remarks like should have brought a golf turbo as ive had turbo's in the past and wanna do something different. :smiley:
Offline sharki786
  • GOT BOOST??
Re: Mk 4 engine transplant
« Reply #1 on: 30 June 2011, 13:42 »
think they the same engine. i might be wrong. just look at the mounting point (engine mount and gearbox mount. if kells did the audi BAM convo then im sure you can aswel. also people will say why not just buy the car, but its good experiance to diy it.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline SoundillusioN
« Reply #2 on: 30 June 2011, 15:11 »
Same engine, although early mk4 GTI 20vT started life as 150bhp and all Cupra R's were the 180.................... I think.
« Reply #3 on: 30 June 2011, 15:36 »
Leons are a minfield, Sport is 150bhp, Cupra is 180bhp and Cupra R is 225bhp (early ones were a little less I believe).
As for fitting to a mk4, no point in building what you can buy, a mk4 1.8t (150bhp) will with mods and a remap make the same power.
So no point in doing the conversion all the 1.8t are the same basic engine with changes to cope with extra power.
« Last Edit: 30 June 2011, 15:40 by Wayne »
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #4 on: 30 June 2011, 21:49 »
Cupra R engine is same as mine, they were either 210 hp or 225, only difference between them is the map on the ECU, engine codes are AMK and BAM, they both map to exactly the same and as i say, they are the same engine so it does not matter which you go for if your gonna remap :wink:
Reason the AMK was 210 is because audi wanted the TT to be abit more powerfull than the S3 on its launch, then a while after they did the facelift S3, and seat facelifted the cupra R, its at this point they got the same map as the TT  (225hp)
Normal Cupra was 180 hp which is same as what wayne has in his VRS and also what was in the Annie MK4 golf
Worth noting the AMK / BAM is a much different set up to the rest of the 20vt engines, got the much better K04 for a start, plus a load more stuff i wont bore you with, basically you can get bigger power gains easier but the trade off is the AMK / BAM set ups sell for 2k +
« Last Edit: 30 June 2011, 21:51 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
