Author Topic: Water Meth  (Read 2060 times)
Offline Grand Master Patch
Water Meth
« on: 29 June 2011, 21:54 »
Anyone run it?
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Water Meth
« Reply #1 on: 29 June 2011, 23:09 »
 :rolleyes:
Just water not meth as I only need the combustion cooling factor.  Sunday around 12.30pm during the heat wave I was logging 19psi boost, 13deg AIT reading, fuel 13.5:1 5500rpm,  with 23deg of ignition advance with zero ignition pull. and the car was pulling very stong as it would on a cold winters morning. While everyone was having issues with heat soak, peak cylinder pressure det and major ignition pull.
 01455 617233
Offline The Doc
  • E63s Estate - Vito Sport
Re: Water Meth
« Reply #2 on: 30 June 2011, 08:53 »
I drank loads of water, it was hot hot hot on the dyno on Saturday  :drool:
Offline RTechUK
Re: Water Meth
« Reply #3 on: 30 June 2011, 08:56 »
I nearly passed out sunday from a lack of sleep and a lack of water combine witht the heat.. :sick: N
 01455 617233
