Author Topic: horney blonde babe needs help!!!random cutting out,  (Read 2075 times)
Offline RIPP3Y
hi, my 2l gti keeps dying on me on a daily basis.
 there is no warning when this happens, but you no its gonna happen on every trip. i fitted a K&N cone filter a few months ago but cant see how that would cause this issue, ive since put the original airbox back on.   I also fixed a hissing noise comming from the servo which i thought would cure the problem but no such luck, I dont think its an air problem so could only be fuel or electric?,  When the car cuts out, the ignition lights stay on, it takes a few minuits befor the car will fire up again. It sometimes cuts out but then jumps back to life just as i reach for the hazard switch.
  What do you suggest??
Offline RIPP3Y
Re: horney blonde babe needs help!!!random cutting out,
« Reply #1 on: 29 June 2011, 14:04 »
btw, thanks for the tip ShelaghGti :grin: :grin: :grin: :grin: :grin:
Offline VR6_Wherry
« Reply #2 on: 29 June 2011, 14:08 »
"horney blonde babe" AKA - 39 year old Welshman..
 :laugh: :grin:
I'm sure Robz will help you out, he loves men.
Offline Len
« Reply #3 on: 29 June 2011, 14:42 »
A sex change op?
www.sas.org.uk
www.the-ace.org.uk
Offline robz
« Reply #4 on: 29 June 2011, 14:46 »
 :laugh: :grin:
cheeky bastard!!
i would do a search mate but sounds like crank sensor or coil pack ;)
Offline stainesy
« Reply #5 on: 29 June 2011, 14:49 »
I had exactly the same. If it starts up again once the coil has cooled down then I'd say coil.
Offline robz
« Reply #6 on: 29 June 2011, 15:06 »
yeah, i went through 3 in a row on mine!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 29 June 2011, 19:42 »
crank speed sensor.
Offline ashbreed
« Reply #8 on: 29 June 2011, 22:28 »
+1
Offline gasketface
« Reply #9 on: 30 June 2011, 07:57 »
relay number 30 ?
