Author Topic: Fuel pump buzzing  (Read 1311 times)
Offline Lee Watson
Fuel pump buzzing
« on: 08 April 2005, 14:29 »
I have a MK2 golf GTI 16V 1990 and I've noticed a buzzing from under the car and it's coming from the area where the fuel pump is located. Anyone no how to check a fuel pump?
 :huh: :huh: :huh:
Offline tobz.
Re: Fuel pump buzzing
« Reply #1 on: 08 April 2005, 14:41 »
The only way to really check your fuel pump is to 'break' a fuel line and fit a pressure gauge inline. Most people wont have one of these lying around so it's probably best left to a garage with the right equipment.
Main fuel pumps on mk2's are well known for being noisy so it's probably ok anyway.
There are two main reasons for a noisy pump in the first place:
1) The lift pump in the fuel tank has gone leading to the main pump having to work harder, it might be worth replacing your lift pump just incase as once it goes the extra strain on the main pump will lead to premature failure.
2) The main pump is starting to wear and becoming noisy. This is the first sign of failure but they usually go on for quite a while (sometimes years) after they have become quite noisy.
Hope this helps
Tobz
You got any pics of your dad's split ?
Offline Lee Watson
« Reply #2 on: 08 April 2005, 14:43 »
free
« Reply #3 on: 08 April 2005, 16:31 »
buzzin  :cool:, it's went it starts sqreekin 2 you wanna worrie mate :wink:
