Author Topic: fuel pump straining ?  (Read 1410 times)
Offline lord14
« on: 28 June 2011, 10:15 »
i have an inline pump witha 3bar reg on a 1.8t engine , and for some reason its all of a sudden started straining , ive put a guage before the rail to test fuel pressure and its at 4 bar , its just when i connect to the rail it starts straining really bad and then melts the fuses and makes the wire hot
Offline AudiA8Quattro
Re: fuel pump straining ?
« Reply #1 on: 28 June 2011, 12:43 »
Blocked fuel filter?
Offline lord14
« Reply #2 on: 28 June 2011, 12:47 »
fuel filter is fine , ive even tried it without it , and still no luck
« Reply #3 on: 28 June 2011, 16:05 »
If there is no blockage then i would think the pump itself is at fault.
The pump could be ok until its properly under load.
Maybe try a cheap second hand unit?
Offline lord14
« Reply #4 on: 28 June 2011, 16:17 »
think ill have to mate , thanks alot
« Reply #5 on: 28 June 2011, 20:09 »
Are all the fuel lines clear and unkinked etc.
Offline lord14
« Reply #6 on: 28 June 2011, 22:38 »
yeh all fine ,
