Author Topic: Gti Indicator problem  (Read 1182 times)
Offline markymarkg
« on: 25 June 2011, 23:36 »
The indicators have packed in on my car and not sure what to do.
They have been a bit trouble some this last couple of weeks in they stop working but i found if i waggled the stalk up and down fast they started working again but now that doesn't fix them. Even the hazard lights have stopped working. The button just lights up when pressed but doesn't flash but when i trigger the alarm the indicators flash as normal.
Is it just the stalk thats at fault or could it be the relay or something worse??
Offline markymarkg
Re: Gti Indicator problem
« Reply #1 on: 29 June 2011, 22:27 »
I have changed the indicator stalk now and no different.
Fuse is next on the list tomorrow from VW. Is it relay #191?
Also the airbag light is now on because i had to take the steering wheel off - how is it reset??
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 29 June 2011, 23:21 »
Edit : Run Vagcom on it, you'll be able test the airbag system on that and it'll turn the warning light off if there's no faults.
« Last Edit: 30 June 2011, 19:40 by thai-wronghorse »
Offline markymarkg
« Reply #3 on: 30 June 2011, 19:32 »
Its not the abs light thats on its the airbag warning light..
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 30 June 2011, 19:40 »
Defo sounds like flasher relay ,as for the air bag fault, light should go out after its self check regardless if the wheel has been off ,recheck the connector to the bag. :smiley:
« Reply #5 on: 30 June 2011, 19:41 »
Doh - edited.  :embarassed:
Offline markymarkg
« Reply #6 on: 02 July 2011, 01:30 »
sorted the indicators, it was just the relay but the airbag light is still on. I have checked the clip underneath the cowl for the airbag wires and seem perfectly fine.
Offline Screech16v
  • MK3 20vt AGU
« Reply #7 on: 02 July 2011, 16:12 »
Looks like it needs hooking up to vag com or fault code reader,whats your location ,maybe some one on here is close with either :smiley:
Offline markymarkg
« Reply #8 on: 05 July 2011, 19:44 »
I'm in Glossop near Manchester.
