Author Topic: what will a DV do?  (Read 4544 times)
m4t_lee
what will a DV do?
« on: 24 June 2011, 23:25 »
Never had a turbo'd car before, have heard a lot of noise about DV's, what do they do, what do i get from putting a better one on, will putting a better one on cock anything up or ruin mpg?
What benefits if any are there?
Cheers,
Mat
Offline Komenda
Re: what will a DV do?
« Reply #1 on: 25 June 2011, 09:59 »
Basically, it allows the pressure that has built up when on throttle, to be released. If the pressure wasn't released then it would stall the turbo, and break it quite badly. A diverter valve releases the pressure back into the intake system, where as a blow off/dump valve let's the pressure back out into the atmosphere, hence you get that annoying noise that Skylines and Imprezas make.
An improved Diverter valve will not leak and let boost pressure out of the system, making the engine more responsive and build boost quicker. It will also be better for a remapped engine as the standard ones are quite fragile (depending on year of make) when asked to hold more boost pressure.
Offline Black9
« Reply #2 on: 25 June 2011, 11:03 »
How much do these DV cost and what brands would you recommend!?
Offline daz veedub
  • Operation 1.8t bolf
« Reply #3 on: 25 June 2011, 15:23 »
awesome gti do the 007p which is same as the forge 1 but cheaper  :wink:
http://www.golfgtiforum.co.uk/index.php?topic=94010.0
Offline Rhyso
« Reply #4 on: 25 June 2011, 16:10 »
And won't fit the MK5 GTI  :tongue:  I think you're a little lost......
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260306&product=FMFSITVR
Offline Komenda
« Reply #5 on: 25 June 2011, 16:18 »
I had the Forge one on mine. Not the mk4 one though  :grin:
I've heard people say the latest version VW one is as good.
Offline AlanD
  • MK5 2.0T 16v
« Reply #6 on: 25 June 2011, 16:21 »
Snap, got a Forge one on mine but as the wise man has said, latest VW one will do the job just as well (if not better?).
LOL @ the lost MK4 owner :D :D
m4t_lee
« Reply #7 on: 25 June 2011, 17:42 »
how do i know if i have an old or new one on? it's an 06 reg
Offline daz veedub
« Reply #8 on: 25 June 2011, 17:44 »
hahahahaha clicked on wrong flippin section
Offline Komenda
« Reply #9 on: 26 June 2011, 13:26 »
If it's never been changed you have the old one on that year car
