Author Topic: Oil temprature?  (Read 1479 times)
Offline Craigwilson
Oil temprature?
« on: 24 June 2011, 23:19 »
What should the oil temprature normally be the mfa says it is usually about 100 little more when im driving it hard but when i swap the spade with the one on the vdo it says 130 why is this?
P.s. Why doesnt my water temp guage on the dash work.
Offline Simeon
Re: Oil temprature?
« Reply #1 on: 25 June 2011, 00:24 »
What engine? My 8v gti sits at 94ish normally, up to 116 when thrashing it on a track
Offline Mitching
Re: Oil temprature?
« Reply #2 on: 25 June 2011, 01:00 »
My 8v digi sits at around 90, goes up to 100 if I'm in traffic or driving a bit more 'enthusiastically'.
The water temp gauge on your clocks?
Offline Simeon
Re: Oil temprature?
« Reply #3 on: 25 June 2011, 01:33 »
Oh, if yours is a digi, the water temp gauge won't be working because the black sensor in the plastic water housing at the front of the engine is knackered, they're cheap from gsf
Offline Craigwilson
Re: Oil temprature?
« Reply #4 on: 25 June 2011, 02:30 »
Well my temprature is about right then on the dash but does anyone know why the vdo temprature guage reads 130 when its actually about 100.
Oh and ill get a replacement black temp sender i suspected it was that but i dont know the difference between the blue one and the black one.
Offline Simeon
Re: Oil temprature?
« Reply #5 on: 25 June 2011, 10:57 »
Black one is for the dash gauge
Blue one is for the ECU
Offline mk2bal
Re: Oil temprature?
« Reply #6 on: 25 June 2011, 11:29 »
The vdo needs a different rate variable resistor (sensor) that's why you'll get two different readings.. You need to use a sensor rated to the vdo gauges for the vdo's, and the black coolant 8v or the small black collared m10 for a 16v dash temp gauge. 100 degs is fine on the oil, its what u need really for water to evaporate/separate from it
Offline Agreeable Slick
  • Unit
Re: Oil temprature?
« Reply #7 on: 25 June 2011, 11:30 »
Search function chaps. Ta. :smiley:
