Author Topic: New ecu update?  (Read 3514 times)
m4t_lee
New ecu update?
« on: 24 June 2011, 23:13 »
Coming from a mk4 r32 a common problem was the car not having the latest ecu update from the dealer which made the car more drivable, is there one i should be looking at getting for the gti, if there is will it be negated by a remap anyway if i get one?
Cheers,
Mat
Offline Komenda
Re: New ecu update?
« Reply #1 on: 25 June 2011, 10:00 »
Get a VW dealer to check the chassis number and see if it needs an update. There have been a couple, but if it's been serviced at a main dealer they should of been done.
m4t_lee
Re: New ecu update?
« Reply #2 on: 25 June 2011, 17:44 »
cheers chap, there have been 3 apparently, ecu, clutch i think and coilpacks, it's only missing the coilpacks so will get it book in
Offline _Adam_
Re: New ecu update?
« Reply #3 on: 04 July 2011, 13:50 »
is this a free service by any chance?  :undecided:
Offline Rhyso
Re: New ecu update?
« Reply #4 on: 04 July 2011, 13:54 »
It is; well it should be  :smiley:
Best thing to do is ring VW with your chassis number and check; you may find your engine is up to date anyway  :smiley:
Offline _Adam_
Re: New ecu update?
« Reply #5 on: 04 July 2011, 13:57 »
i dont think it is as it's a 53 plate (one of the oldest!!!) and everyone else with a 140 seems to get better mpg than me. i know i'll be after a remap soon anyway, but would be nce to have it sorted for the next 2 months
Offline Rhyso
Re: New ecu update?
« Reply #6 on: 04 July 2011, 13:59 »
What you currently getting? If you've got an underlying problem then a remap won't cure it, it will make it worse  :sad:
Offline _Adam_
Re: New ecu update?
« Reply #7 on: 04 July 2011, 14:05 »
get about 39 - 42 bridgend to cardiff. 60-80mph. loads of others say they get 50+ on a steady run :sad:
Offline Rhyso
Re: New ecu update?
« Reply #8 on: 04 July 2011, 14:07 »
Has it ever been better than that or has it always been like it since you had the car?
Offline _Adam_
Re: New ecu update?
« Reply #9 on: 04 July 2011, 14:09 »
Always the same
