Author Topic: brake calliper bolts? help?  (Read 2359 times)
Offline sellers
  • Daz Works in Health and Beauty
« on: 07 April 2005, 21:07 »
for some great reason all 4 on my 1.6 driver have been rounded to i cant undo them with an allen key, any suggestions how to get them out, and where to get some replacements
cheers
Can't think of a funy or whitty comment
Offline Mr Blue
Re: brake calliper bolts? help?
« Reply #1 on: 07 April 2005, 21:18 »
smack a slightly bigger socket over the whole bolt itself and this should undo it. Tip was given to me by '6' and its a top tip.
buy the bolts direct from vw for about 40p or something
Offline ...joe
« Reply #2 on: 07 April 2005, 21:19 »
or get a set of molegrips on them. these are a f**k*r and almost everyone will have had these problems before!!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline fin170703
  • if its not broke fix it anyway
« Reply #3 on: 07 April 2005, 21:30 »
Had the same problem. i used heat and molegrips seemed to do the trick
Offline sellers
« Reply #4 on: 07 April 2005, 21:36 »
mole grips, lol, yeah i tried them and well i tried to hard that the head of it now is all mangled up, no matter how tight i put them on it still twisted off, what did u use to heat a blow lamp? think i might cut the head off so i can get the caliper off and then try and get the mole grips onto the remaining thread?
are the ones on gti's the exact same bolt or not
Offline fin170703
« Reply #5 on: 07 April 2005, 21:37 »
oxy/acetelene mate  :evil:
Offline Mr Blue
« Reply #6 on: 07 April 2005, 21:44 »
dont cut them off. i did that and it took agez and was a messy job with the angle grinder :evil:
soak them in WD40 over night. Then smack a socket over the whole bolt and undo it that way. it will come off in seconds :smiley:
Offline LPG'd Oakie
  • Haha...I own one now!!!...And it works...ish
« Reply #7 on: 07 April 2005, 22:10 »
Hmmm, guess it was you that just asked me on ebay if i had them!
Offline sellers
« Reply #8 on: 07 April 2005, 22:36 »
lol, small world, i sent the money for the clocks this morn, should arrive tomorro or sat
cheers
Offline sellers
« Reply #9 on: 09 April 2005, 13:20 »
ok so i finnally did it, got the bolts from main dealer at about 39p a bolt,
and the way i got them off was with smacking one of those star shaped bits that was bigger than the original 6mm into it and turning off with a rachet, came off realy easy. :smiley:
cheers for the help guys
