Author Topic: judder under braking  (Read 1579 times)
Offline ryegault
« on: 23 June 2011, 17:29 »
my car has recently started to judder under medium braking, felt through the steering.
also sometimes under harsh acceleration.
i gave it a jack up at the front and checked for play, with one hand at the top and one at the bottom of the tyre, there is a slight amount of play (not sure if this is normal or not) any ideas?
also a different problem not related to this,
when cruising around theres a bit of a knock when going over small bumps in the road.
thanks
Offline AudiA8Quattro
Re: judder under braking
« Reply #1 on: 23 June 2011, 17:30 »
Where is the play? there should be any.
Offline ryegault
« Reply #2 on: 23 June 2011, 17:43 »
when the front wheel is off the ground, you move the top in and the bottom out, and vice versa.
« Reply #3 on: 23 June 2011, 17:44 »
Yes, what i meant was where is the movement, is it is the wheel itself, or is the suspension moving?
Offline ryegault
« Reply #4 on: 23 June 2011, 17:48 »
ah ok, its as if the coilover is flexing
« Reply #5 on: 23 June 2011, 17:51 »
Top mounts worn?
Offline ryegault
« Reply #6 on: 23 June 2011, 18:04 »
would that cause the heavy judder?
« Reply #7 on: 23 June 2011, 19:05 »
Any significant suspension wear could cause it yes.
