Author Topic: Front discs from GSF, anyone tried them?  (Read 4383 times)
Offline richandhazel
Re: Front discs from GSF, anyone tried them?
« Reply #20 on: 11 April 2005, 12:54 »
No need to do the wheel bearing unless it is on its way out...........quite a big job as you need a hydraulic press to remove/refit it.
You'll probably need an impact driver to remove the screw that holds the disc on.........if you snap the head off don't worry as the wheel bolts are the primary method of securing the disc.........just more hassle aligning the bolt holes.
Offline Deefadog
  • Mk2 16V (November 89)
« Reply #21 on: 11 April 2005, 13:15 »
Cheers I did not realise it was such a big job :)
Sorry to sound dumb, but what is an impact driver?
I was planning on using a blowtouch on the stubborn bolts :) Should i replace the bolts? I need to get everything ready to do this :)
I did the wheel bearing on the rear of my old golf about 5 years ago, i don't remember it being a difficult job! just lts of grease :)
are the rears different?
« Reply #22 on: 11 April 2005, 13:31 »
Yeah the rears are taper bearings...........much easier. Fronts are interfearence fit straight bearings, to do it properly you really do need a press to push the bearing out.
Offline Deefadog
« Reply #23 on: 11 April 2005, 13:52 »
I see :) thanks
So should i get new bolts for those front discs before i start hacking at them?
« Reply #24 on: 11 April 2005, 14:42 »
I see :) thanks
What bolts do you mean? You won't need new wheel bolts. Do you mean the single countersunk screw that holds the disc on? Sorry I meant to say, an impact driver is a tool that you put the screwdriver bit in and wack with a hammer to undo the screw. Here is one:-
http://www.machinemart.co.uk/product.asp?p=040212830
Chances are if the screw won't come out, you'll snap the head off...........don't worry about it......the screw is merely there to prevent the disc turning on the hub. You can do with out it and its a lot more hassle than its worth trying to get the broken shank out.
Offline Deefadog
« Reply #25 on: 11 April 2005, 15:17 »
Thanks for the info, learn something new everyday :)
I'll let you know how it goes :)
Offline Gambit
« Reply #26 on: 11 April 2005, 15:44 »
put some copper grease round the retaining screw next time you fit it, that way it wont seize
« Reply #27 on: 11 April 2005, 15:47 »
Yep, I use that stuff nearly everywhere..........saves a lot of hassle if you ever have to dismantle again :wink:
Offline Deefadog
« Reply #28 on: 11 April 2005, 16:48 »
I use it also, thanks for the reminder :)
