Author Topic: Front discs from GSF, anyone tried them?  (Read 4384 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re: Front discs from GSF, anyone tried them?
« Reply #10 on: 07 April 2005, 16:30 »
I'm off down there too! will let you know, £20 for the pair, cpould be the same ones he qouted me with the vat :)
take care
Offline Gambit
« Reply #11 on: 07 April 2005, 16:36 »
they also do an inclusive offer on Brembo Max disc's and Pagid Fast Road Pads - so ask about that also
Offline Deefadog
« Reply #12 on: 07 April 2005, 16:47 »
Thanks Gambit!
I am only going to replace the fronts for now, will this matter having the standards on the back? or should i change them all with the same?
ta
Offline Gambit
« Reply #13 on: 07 April 2005, 16:52 »
nah it wont make a difference. rears only make up about 20% of the total braking force anyhow. just keep std pads & disc's on the rears
Offline Deefadog
« Reply #14 on: 07 April 2005, 16:55 »
Cheers mate :)
I am hoping that one of the existing disc's is warped, and that is the cause of the juderness when i come to a stop :) if not it cost more :) lol
Offline Gambit
« Reply #15 on: 07 April 2005, 16:58 »
did you ever get your rear wiper sorted? or just give up on it?
free
« Reply #16 on: 07 April 2005, 17:26 »
i had them on my 8v, , then got some drilled 1's wat cracked :angry: the standed spec gsf 1s did job fine  theo
Offline Mart8V
  • I really should know better by now.....
« Reply #17 on: 07 April 2005, 21:34 »
Am 3000 miles into a set of GSF front discs on my 8V- all seems well so far.  Last set were VAG and I haven't noticed any difference yet.  Am using the standard Pagid front pads.
Offline Deefadog
« Reply #18 on: 07 April 2005, 22:08 »
Good to know guyz thanks
Gambit- have not given up yet :) I am getting a second wiper stalk and see if that does the trick, i'll get that relay back to you ASAP
Offline Deefadog
« Reply #19 on: 11 April 2005, 12:39 »
I ended up just getting the stadard discs and pads - £36ish for the two sets of discs and pads, not bad :)
Any pointors on changing these, things to look out for?
also is this a good time to do the wheel bearings? i mean as i am down there is it an easy job?
cheers
