Author Topic: Indicator issue and coolant hose connector  (Read 1330 times)
Offline Tboy
« on: 21 June 2011, 03:26 »
Got a problem with my indicators, the left one works sometimes and the right not at all unless i fiddle with the lever a bit and then sometimes it comes to life. The hazards are the same, sometimes working sometimes not, repeated pressing of the button sometimes makes it kick in. Do i need a new indicator switch? Fuse? Relay? What about for the hazards?
Also a plastic unit that connects the engine to the coolant hoses is leaking.
This thing. It has a number on it, PA66-GF35 although the last two digits might be different, can't make them out 100% clearly. Is this the part number? Does this thing have an official name?
Offline Tboy
Re: Indicator issue and coolant hose connector
« Reply #1 on: 24 June 2011, 05:49 »
Is it an air intake manifold?
Offline Craigwilson
« Reply #2 on: 25 June 2011, 02:44 »
Sounds like the switch is just worn out but i would try the relay first you never know its relay number six i think, should have a 21 on it.
