Author Topic: what's the Correct oil not on longlife ?  (Read 8200 times)
Offline Steve30
  • Ed30 .
« on: 20 June 2011, 11:25 »
What is the correct oil VW use when not on longlife servcing ?  :undecided:
« Last Edit: 20 June 2011, 11:34 by Steve30 »
Tiguan quicker than the Golf
Offline am1w
Re: what's the Correct oil not on longlife ?
« Reply #1 on: 20 June 2011, 11:47 »
Steve, just use longlife oil. Saves lots of hassle.  :smiley:
Offline Steve30
  • Ed30 .
« Reply #2 on: 20 June 2011, 11:53 »
NO No NO , its not on longlife Asker  :rolleyes:
Offline mike.
« Reply #3 on: 20 June 2011, 12:06 »
My dealer just uses long life whether you are on time and distance or variable..
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Steve30
  • Ed30 .
« Reply #4 on: 20 June 2011, 12:13 »
Mike the dealer says he used 5-30 shell oil thats the same as longlife right?
Offline Phil1980
« Reply #5 on: 20 June 2011, 13:16 »
yes 5-30 fully synthetic,
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline Hyperspace
« Reply #6 on: 20 June 2011, 13:26 »
502/505 oils may be used for the Time/Distance regime.
504/507 oils may be used for both Time/Distance and LongLife regimes.
And 504/507 oils are better for FSI/TSI/TDI engines, irrespective of regime, so go with the latter.
« Last Edit: 20 June 2011, 13:28 by Hyperspace »
Offline Steve30
  • Ed30 .
« Reply #7 on: 20 June 2011, 14:14 »
Phil , so I can use any oil as long as its 5-30 ?  :wink:
Offline R32UK
« Reply #8 on: 20 June 2011, 14:26 »
use long life oil for both t&d and long life  :wink:
Offline Phil1980
« Reply #9 on: 20 June 2011, 14:46 »
The stuff the dealers use and most independents I believe is Castrol 5-30 and is fully synthetic.  Obviously you could try another brand but I think that is pretty much the best there is available.  Important thing is regardless of what service plan you are on you use the same stuff, the independent garage I visited also used the same oils.c
