Author Topic: chip or re-map, whats the differance?  (Read 3103 times)
Offline mr mk2
« on: 19 June 2011, 23:24 »
so what is the differance between a chip and a remap or are they the same power increase just a differant way of doing it? which would be better 4 my mk2 gti 8v with 2.0 bottom end?
Re: chip or re-map, whats the differance?
« Reply #1 on: 19 June 2011, 23:44 »
A remap is better if available however yours will be chip only and the gains if any are small.
« Last Edit: 20 June 2011, 10:27 by Wayne »
Offline Martz
« Reply #2 on: 19 June 2011, 23:48 »
yours would be chip only. would not bother for a 5bhp increase.
Offline mr mk2
« Reply #3 on: 19 June 2011, 23:55 »
why would mine b chip only cant i get it remapped then
Offline Sam
  • Sam I am
« Reply #4 on: 20 June 2011, 01:21 »
Definitely not worth it, you wont even notice it, will be purely bragging rights
Offline Agreeable Slick
  • Unit
« Reply #5 on: 20 June 2011, 08:45 »
Because is has bog all electronic control on it. Concentrate on other things tbh.
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #6 on: 20 June 2011, 12:27 »
A chip and remap are the same thing at end of the day, the software is getting edited (re calibrated / remapped)  So a chip is a remap at the end of the day, its just then method used to get the remapped software on to the ecu.  With a chip you have to open the ecu and remove the chip to write the new map to the ecu, then you have OBD remap which flashes the map via the OBD port in the car and no need to touch the ecu.
 01455 617233
Offline Bigdunc
« Reply #7 on: 20 June 2011, 17:27 »
The chips are rubbish I got one and took it out same week smoothed engine buy no real difference on speed and it drank fuel :(
Offline emery1990
« Reply #8 on: 20 June 2011, 18:15 »
Rubjonny got good results with one, but that was on an abf. An ebay chip too.
« Reply #9 on: 20 June 2011, 20:31 »
I would avoid ebay chips tbh
