Author Topic: HELP ELECTRICAL PROBELM!!!  (Read 1612 times)
Offline Sandeept
« on: 06 April 2005, 19:18 »
hi
I've got a problem with my 1992 MK2 Golf GTi electrics. I've just recently bought the car and have noticed when I switch my ignition on and car is running the number plate lights stay on, the dashboar lights also stay on and its also possible to switch the front fogs on without the lights being on
Any ideas whats wrong??
Thanks
Offline mk1
Re: HELP ELECTRICAL PROBELM!!!
« Reply #1 on: 09 April 2005, 17:47 »
Strange one that :undecided:, check the wiring that goes from the body to the tailgate and the front doors as this can brake and cause shorts and back feeds.
Steve.
« Reply #2 on: 10 April 2005, 10:19 »
First thing I'd do is swap in another headlight switch, make sure you get one of a late MK2 with the hazzard swtch on the column though as I think they are different to the early ones!
If that don't help take the dash under tray off and check for dodgy wiring around the ignition switch, could be someone has been fiddling to bypass a knackered ignition switch.
